Author Topic: FU-Dyson-BMS - An (Unofficial) Firmware Upgrade for Dyson V6/V7 Vacuum BMS  (Read 102643 times)
Offline m0nst9ra
  • Country: ru
Hello tinfever! Thank you for helping ordinary people bring old Dyson batteries back to life. Such a question, my Dyson battery was blocked, but after disassembly it became clear that the cells were still in fairly good condition, and apparently the battery was blocked due to imbalance.
I flashed the PIC with your firmware, charged the battery, now the voltages of all cells vary in the range of 4.15-4.25V. But I ran into a problem..
The PIC does not allow startup and flashes blue 3 times, indicating that the battery is low. This is at any battery charge level.
What have I tried:
1. Replaced ISL, no changes
2. I checked all the voltages coming to the CELL terminals (ISL) 25-20.7-16.55-12.38-8.24-4.10+VBACK.
3. Checked the entire ISL binding.
--There is an interesting feature, when charging is connected, it flashes 82 times in red + blue, telling us that there is an imbalance of min-max, 82*50mV = 4.25V, so it does not see the voltage of any of the cells? I connected the oscilloscope to the AO ISL-PIC line, based on the oscillogram and firmware, no problem is visible. Maybe you have a guess what the problem is. Thank you very much!
Offline starfish
 :box: dyson :box:
Offline taiyuanshanxi
  • Country: cn
Thank you for the open source, my programmer is back, I have to try to flash the firmware of the V10 to get the V10 vacuum cleaner back, my charge equalization is mixed charging with 6 x 5v power supplies and IP3212, if the connection is not correct, it smokes and burns 2312, I have burned a few and the correct connection can charge. Thanks again to the author of V6 open source, I'm really sorry that my English level is close to zero because I didn't like to study when I was a kid, I use translation software to translate,
« Last Edit: May 30, 2024, 03:28:34 pm by taiyuanshanxi »
Offline rulof
  • Country: ru
Hi!  :-+
First of all my deep congratulations for all of the hard job that you did here, specially tinfever  :-+
I know it's a little "off-topic"  but I post here because I think it could be interesting,  yesterday I opened a old DC35 battery, It´s also a 6 x 18650 battery but with a different BMS MCU
- Part number at battery case 17083-22 12
- Part number at BMS board   17522 01-05
I can confirm that the MCU in this BMS board is the ATTINY44-20MU 20-QFN-EP
After reading datasheet I connected my USBasp pogrammer to:
Pin 16  MOSI
Pin 20  MISO
Pin 13  RSET
Pin 1     SCK
Pin 8    GND
Pin 9     VCC (+5V)
I succesfully downloaded Flash + Eeprom but I don´t have enough knowledge in dissassembly these files to do something interesting as tinfever did
If someone it´s interested I can upload here
Best regards
Hello, did you write about the DC35 firmware once? I'm trying to revive my battery. Did you manage to do it? If possible, send me your files.
I also counted flash and eeprom, but I don't know how to fix the eeprom to unlock it.
Offline Jimmy Electron
 Hi Tinfever and hat off to you and your co-conspirators for your diligent work.
 You asked for feedback to help the project.
 So, I have an SV03 pack which had stopped running for any more than 1 minute or so. Without looking into solutions, I merely renewed the 18650 cells at which point it started the 32 red flashes nonsense.
 It was at this point that the EEVblog threads and your work in particular came to my attention.
 Anyway, three months later, the SV03 is just now flashed - Although not working.
 When the trigger is pressed the motor starts and the LED's flash green, red, blue.
Then after a second or two, the motor stops and the blue LED flashes three times, This blue flash sequence repeats another three times (four in total) before going to solid green for a while, then off.
 Placing on the charger flashes yellow twice, before switching to solid blue, then green, then off.
Question, "Is it still charging whilst the LED is off?"
 Upon release of the trigger it displays six green flashes (although I am sure it was five at first).
 Measuring the battery voltage gives a reading of 23.5v
 "Is it just a question of needing to be left alone overnight to charge?"
 "At 75 - 125mV could the battery cells be too out of balance?"
 I suppose I'll see in the morning... :popcorn:
 Ok, an update..
 No noticeable change after several hours charging.
 Still six green or two yellow flashes depending on test, and 23.5v across the battery terminals.
 One thing that has come to light is that when I press and hold the trigger, the MAX light comes on. Then almost immediately the battery dies, until being placed back into the charger.
If the trigger is not held, as in it is 'pulsed', then the Dyson can be used for a long time witout the battery failing.
 This is leading me to consider the possibility that the main pcb has a problem.
 Not sure how easy it is to extract it but if at all possible I'll trace the circuit from the MAX button and see if perhaps a transistor has shorted and is keeping the motor at full power?
*Correction;
 When the trigger is pressed it flashes Red then Green - No Blue.
 Update;
 The MAX button switches between Gnd and pin 14 of a PIC16F1936 microcontroller. Therefore the idea that the MAX circuit can be easily disconnected is a non-starter as I'm quite sure that the PIC16 can't be removed and the Dyson still work.
 Shall keep trying to turn off the MAX boost feature
 Edit:-
 Turned out the MAX switch had failed with the MAX boost selected.
 Managed to switch it off by soldering a wire onto Gnd and touching it to the PIC16F1936 pin 14 whilst holding in the main power switch.
Possibly never was a battery problem in the first place, just the MAX button had failed at the wrong time.
 Fingers crossed, but all seems to be working. The LED is purple whilst on the charger....
 Edit 2;-
 Great news. The Dyson just did it's first successful house clean of the year!
 For what it's worth, there is now three yellow, and five green, flashes - But it works
« Last Edit: July 16, 2024, 01:29:22 am by Jimmy Electron »
Offline Greybeard
Quick question:
Can I use my XGecu TL866II Plus programmer to flash the new firmware into a Dyson V6 (SV03) BMS?
Offline tinfeverTopic starter
  • I like to make life harder for myself
*Correction;
 Update;
 Edit:-
 Edit 2;-
Sorry I didn't reply sooner. I'm not familiar with a max button on the battery. The max power mode on the vacuums only controls the motor and how much current it draws. The only thing the battery should see is a higher current draw when the vacuum is in max mode. If the vacuum works in normal mode, but not in max mode, it's likely your battery cells have a higher internal resistance, causing one of the cell voltages to rapidly go below the 3V low battery level when loaded. If so, your only options are to either replace the battery cells (maybe just one if there is only one problematic one, you'd have to test them) or stick to normal power mode.
Quick question:
I think this can be done.
The Dyson BMS uses a PIC16LF1847 but someone successfully programmed one using a programmer set for an PIC16LF1829. There was some issues with getting the configuration bits set right as you can read about here:
https://github.com/tinfever/FU-Dyson-BMS/issues/9
I'm not sure what exact programmer they were using, but I suspect it was a similar universal programmer.
Offline dvdiamond
  • Country: ru
Re: FU-Dyson-BMS - An (Unofficial) Firmware Upgrade for Dyson V6/V7 Vacuum BMS
« Reply #134 on: August 07, 2024, 04:50:00 pm »
Hello. Could you please compile a hex file with MAX_CHARGE_TEMP_C = 60. 12 red signals are annoying  :-[
UPD
I installed MPLAB X IDE and made the firmware as I like. :-P
« Last Edit: August 09, 2024, 06:34:21 pm by dvdiamond »
The following users thanked this post: usup
Offline usup
  • Country: ru
« Reply #135 on: August 16, 2024, 01:38:56 pm »
I also have this problem (12 blinks) can anyone share the corrected firmware?
« Reply #136 on: September 11, 2024, 10:17:30 am »
 A quick update.
 The yellow flashes didn't resolve themselves as hoped and in fact only got worse, to the point that the battery became unusable.
 What hadn't been clear to me at the start was that the battery must be balanced FIRST. Before the reprogramming. Anyway, I bought one of those Chinese cell balancers which was next to useless. It came with no clear instructions, no cables and overheated the first time I used it. Therefore the balancing was done individually using a bench power supply.
 It now appears that the battery is finally back in full operation. No more yellow flashes. The correct Red, Blue Green etc. and it held a decent charge for the first time in almost a year.
 A big thank you to all involved.
 Top work!
Offline Ellefan
  • Country: ru
« Reply #137 on: October 17, 2024, 06:01:39 pm »
Hi. Today I replaced the batteries in the v7 vacuum cleaner. After that, I rewired the bms board. The firmware was successful. The vacuum cleaner is working properly, but I noticed one feature. If the vacuum cleaner is installed at the charging station, the blue LED starts to glow, and if at this time you disconnect the charger from the mains (without removing the vacuum cleaner from the charging station), then after a certain time the vacuum cleaner spontaneously turns on for one second and turns off. I've tested this several times, and every time the vacuum cleaner turns on, it means that there is a code in the firmware that triggers the vacuum cleaner to turn on spontaneously.
If you put the vacuum cleaner on charge and wait until the blue LED goes out, then when you disconnect the charger from the mains, spontaneous activation will not occur
« Last Edit: October 17, 2024, 06:07:17 pm by Ellefan »
Offline Jove98
« Reply #138 on: January 06, 2025, 10:18:09 am »
Salutations,
being the recent owner of a self-bricked Dyson V8 SV10 battery pack here are my 5 cents (with apologies for posting here, I did not find a V8 SV10 thread):
Diassembling the pack shows circuit board number 180207-01/04.
Cells were (P-labels are taken from the circuit board) P6 3,46 V; P5 3,83 V; P4 3,81V; P3 3,83 V; P2 3,85 V; P1 3,79 V
(Sorry for the decimal comma - I DO live on the other side of the Channel)
It flashed
- three times red upon pressing and releasing the wake up switch
- three times red followed by once blue upon pressing AND HOLDING the wake up switch.
(And THAT is the reason for posting -- I hadn't seen these patterns mentioned before)
Clearly a dead parrot....
...but twitching: Reading the EEMemory with the ancient "PICkit(TM) 3 Programmer Application with scripting support" (ran that under W...s XP running under VirtualBox on a Mac, to make life complicated but interesting) it identified itself as "PS1 V14. 000.09<0x0D>" in bytes 00 thru 0F.
Bytes 1E and 1F were 0x58 0xCE.
OK, so now for some CPR: Wrote 0x00 0x0F to those two bytes (thanks to secondlife at ).
Parrot now happily charging again :=))))
Let's see how long it lasts. If it fails again too frequently  tinfever's code may come into its rights after all (as soon as I understand it).
Cheers
J
« Last Edit: January 06, 2025, 10:25:03 am by Jove98 »
Offline DavidAlfa
« Reply #139 on: January 06, 2025, 11:09:31 am »
Dude, 60°C is unsafe, don't do that!
Offline vlad4600
  • Country: ru
« Reply #140 on: February 16, 2025, 06:13:03 pm »
After firmware Dyson V7-SV11-PCB228499, it works fine, but when fully discharged, it does not charge and error 8 flashes red. Here is the main file. Who knows how to fix it?
« Last Edit: February 16, 2025, 06:22:43 pm by vlad4600 »
Offline Leonniedas
  • Country: my
« Reply #141 on: February 19, 2025, 02:31:27 am »
I've just replaced the cells in my V6 but now I am getting 14 flashes of the red light. Based on that its an "UNDERTEMP_FLAG" but I don't know how to fix that. Can anybody help?
Thanks!
« Reply #142 on: February 19, 2025, 02:35:40 am »
Thanks!
Check your thermistor. It may have been broken when replacing the cells.
Offline Leonniedas
  • Country: my
« Reply #143 on: February 19, 2025, 03:00:29 pm »
Thanks, unfortunately mine seems to be the older model where the thermistor is epoxied into the case. Will have to see how I can replace it.
Would you happen to know if I can find a replacement thermistor?
My board is the oldest version, PCB 188002.
Thank you for your help
« Reply #144 on: February 19, 2025, 06:14:17 pm »
Make sure you're thermistor is actually broken first by checking it's resistance. It should be roughly 10k ohms at 25C/room temperature IIRC. They are all epoxied into the case which is definitely annoying. Any 10k Ohm 3500k beta THT thermistor will work I think?
 Hi again.
 Another update to report that after six months that the battery pack is back to being useless. We get a few minutes of charge before it dies.
 The flashing yellow LED's have returned, as well as a violet one once it's died.
 When 'charged', as the trigger is pressed, it flashes one red, then five green led's.
 Any suggestions would be great.
Offline ioffe
  • Country: ru
Hello. Thank you for your contribution! I have my own vacuum cleaner sv10 (v8), the battery stopped charging, it was decided to disassemble and inspect the cells. All the cells are normal, and all have 2000+mah, apparently the number of charging cycles or something else blocked the battery. I flashed your firmware, and when I press the trigger, the blue LED blinks 3 times and that's it, there is no power. The voltage is normal everywhere, what could it be? I erased the original sv10 firmware, or rather immediately replaced it with yours without having time to read that it was possible to simply correct the eeprom. Maybe someone has the original SV10 (v8) firmware or how to solve the problem with this, thanks in advance!!!
