ok trying to build a full bridge buck boost converter, please help me troubleshoot a blown mosfet problem, can you see obvious problem? i was just testing it with no load, no inductor, 24V connected to both sides as shown in schematic, and it blew up all the low side fets, high side fets are fine. PWM#2 was inverted from PMW#1, with about 5us dead time between the two. I scoped Vgs from both high and low sides, they peak at 18V down to -5V. i understand that is within acceptable +/-25V range
after it blew up, i removed the lower 4 mosfets, replaced one of them on the input side. tried it again with a slower PWM at 30Hz and seems to have no problems. the gate voltages are fully above threshold after only a couple hundred ns, i dont see how a 500Hz pwm would cause problems
