Author Topic: Review Layout with INA253 (current sensing)  (Read 513 times)
Offline waulu13Topic starter
  • Country: pt
« on: October 23, 2020, 09:08:49 am »
Hello,
I made a simple layout with three INA253 (U1, U2, U3) in parallel. In the beginning I will only solder one. Eventually I will add the second and the third if everything goes well. The datasheet of INA253,
https://www.ti.com/lit/ds/symlink/ina253.pdf?ts=1603359713113&ref_url=https%253A%252F%252Fwww.google.com%252F
I will manufacture the PCB with 1oz and after that I will add solder over the tracks with high current. The conenctors I will use something like this,
https://pt.mouser.com/ProductDetail/TE-Connectivity/796949-3?qs=ItShc8fFPOsPQ5f70MLFFw%3D%3D
So with only one INA253 (10 A), are the layout and the connectors acceptable? Once I add the 2nd and the 3rd INA253 I will keep the tests with 15A maximum just to measure the results and test software. The decoupling capacitors C1, C2 and C3 are well positioned too?
Best regards,
EDIT: The ground is still not connected to the connector.
« Last Edit: October 23, 2020, 09:42:44 am by waulu13 »
