I have 2 HP8904A units.
float measurements taken with 34401a, 10mohm input impedance setting
Supposedly good unit:
channel 1 to earth : 31k (functional light)
channel 2 to earth ; 1k (functional light)
supposedly bad unit (i think it just has a broken indicator light for float)
channel 1 to earth: 45k (good light)
channel 2 to earth : 16k (non functional light)
I hooked up a DC supply to the float control relay and found that if I put enough DC into it I can get the impedance between chassis ground and the supposedly floating thing to read High Z on my 10Mohm input z ohm meter.
Do these units both have faulty relays/relay controllers... or is floating >1Kohm considered good ? I figured float ment broken circuit, so a DC ohm meter should read infinity...
