Author Topic: How to power on the board RockPro RK399 using the TNTOR 10.000mh power bank.  (Read 460 times)
Offline ziomarioTopic starter
Hello.
I've bought the TNTOR 10000mAh power bank to power on my DIY tablet. It has 3 ports :
https://ibb.co/3FV5jnY
Below you can see the soc that I want to power using the power bank :
https://ibb.co/JmLPSQX
The board is the RockPro RK399. It should be powered through 12V / 3A as you can see below (you can find the full specs of the board here : https://wiki.pine64.org/wiki/ROCKPro64
https://ibb.co/LrJDHQ8
What I don't understand is what cable should I use to connect the barrell connector of the board (that requires 12V / 3A minimum) to the powerbank ? And to what USB port should I connect it ? USB A / USB C or Micro USB ? As you can see all these 3 ports are 5V / 2A max input,while the board needs 12V / 3A minimum ; are these voltages compatible ? Can you point me to the right products (cable and / or converter) that I should buy to be able to turn on the board using that power bank ? thanks.
« Last Edit: January 22, 2025, 10:04:37 pm by ziomario »
