Author Topic: Function of a three-terminal spark gap  (Read 1896 times)
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« on: October 02, 2019, 08:05:14 pm »
Hey guys,
I picked this oddity up today at my local electronics store. It seems to be a spark gap, with a fixed and a sliding terminal (sliding terminal has a milimeter scale etched in it) - on a bakelite base. I think it looks 30's-early 50's ish.
The odd part to me is the third, angled terminal below the two other ones. it doesn't have any movable parts, and doesn't really have a screw terminal as the other two, just a 2mm cross hole. it's also very close to one of the terminals.
The guy at the store said he thought it had been used for ignition coil testing, but it doesnt strike me as a mechanic's tool.
Can anyone venture a guess as to its function or origin?
I'm at a loss. Looks good on a shelf of oddities though.
--Chris
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline mikerj
Re: Function of a three-terminal spark gap
« Reply #1 on: October 02, 2019, 08:17:11 pm »
Could be a trigger electrode I suppose.
Offline floobydust
« Reply #2 on: October 02, 2019, 08:21:25 pm »
More about them here:
https://www.eevblog.com/forum/projects/high-voltage-vintage-equipment-question-for-the-physicists/msg1286145/#msg1286145
edit: changed link to post about how the "teaser electrode" works
« Last Edit: October 02, 2019, 09:32:58 pm by floobydust »
Offline Tom45
« Reply #3 on: October 02, 2019, 08:45:41 pm »
In other words, this is a triggered spark gap.
Thanks. Triggered spark gap is something I've never encountered or heard of in my long life until now.
    • My channel:
« Reply #4 on: October 02, 2019, 08:47:32 pm »
that's exactly what I was going to say.
Thanks for the quick responses. good to know.
--Chris
Offline MagicSmoker
« Reply #5 on: October 02, 2019, 09:20:18 pm »
There is even an official name for this contraption: trigatron.
Offline Alex Eisenhut
  • Place text here.
Offline NiHaoMike
    • Facebook Page
« Reply #7 on: October 03, 2019, 12:14:52 am »
With the scale, it looks like a primitive device for measuring high voltage, with the pilot electrode to improve repeatability.
Offline coppercone2
« Reply #8 on: October 03, 2019, 01:15:48 am »
i made one of these with a screw for simple experiments (triggered by bbq starter)
« Reply #9 on: October 03, 2019, 09:41:55 pm »
The guy at the store said he thought it had been used for ignition coil testing, but it doesn't strike me as a mechanic's tool.
Well that's exactly what it is !
Plenty of further examples and discussion here:
Avid Rabid Hobbyist
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #10 on: October 03, 2019, 09:46:51 pm »
Oddly, the pointy electrode design predisposes it to corona discharge, making it less reliable as a measurement tool (besides all the problems with atmospheric discharge in the first place).
Seven Transistor Labs, LLC
Offline floobydust
« Reply #11 on: October 05, 2019, 05:45:55 am »
In one science paper, the teaser electrode arc was said to emit UV which would then start the main arc.
So I tried pointing a UV LED at a spark gap and it hardly makes a difference in breakdown voltage. Thought maybe one could make a light activated spark gap.
Something good for transient generators, ESD guns etc.
Online T3sl4co1l
« Reply #12 on: October 05, 2019, 06:31:38 am »
Or if not the air, then the work function of the electrodes.  Which will be pretty high if made from common metals.
Hm, I don't know offhand if there are even any air-stable metals, intermetallic alloys, or compounds (oxides, sulfides, etc.) that have a work function lower than the ionization potential of molecular oxygen (i.e., ca. 250nm UV).
Offline MagicSmoker
« Reply #13 on: October 05, 2019, 10:20:43 am »
So I tried pointing a UV LED at a spark gap and it hardly makes a difference in breakdown voltage....
The wavelength needs to be closer to the mercury line (254nm, UV-C) to reliably initiate ionization in the gap and almost all UV LEDs emit in the long end of UV-A (~400nm) which is only good for making fluorescent things glow in the dark.
Online Gyro
« Reply #14 on: October 05, 2019, 07:55:45 pm »
UHP Mercury vapour projector lamps use an optically coupled separate UV (<270nm) corona discharge cavity to initiate the discharge in the main (>200 bar pressure) chamber... https://www.lightsearch.com/pdf/uhp.pdf
« Last Edit: October 05, 2019, 07:58:10 pm by Gyro »
Best Regards, Chris
Offline Zapro
  • Breaking stuff to go fix it again
« Reply #15 on: October 28, 2019, 06:44:33 pm »
If you look up the part number molded into the bakelite base, you will find that it's part of this contraption:
http://www.bosch-classic.com/media/bosch_classic/wissen_1/prueftechnik/EFMZ1.pdf
I work in the store and researched the thing before it was sold :)
History of it coming to us: My colleague used to work in a company called Autometer that started out making test equipment / electronic tools for auto repair. He had this thing sitting around for ages, and it apparently appeared in a tidy up at home, and so it sought a new home.
// Per.
