Author Topic: Function of this diode....image included  (Read 862 times)
Offline xwarpTopic starter
« on: December 23, 2019, 04:09:09 pm »
I'm drawing a blank on the function of the diode, but I'm going to guess it's suppose to help turn the transistor off?
 :-// :palm:
So the open end of R3 has a either a low input, or, +5 via a pullup. VDD is +24 vdc
When the circuit it "on", it provides +24 vdc from VDD through the collector to another circuit.
Help me remember what I've forgotten, or, what I never knew.....lol
Thanks!
Offline GromBeestje
Re: Function of this diode....image included
« Reply #1 on: December 23, 2019, 04:44:24 pm »
What kind of load is this circuit supposed to drive?
If it is some inductive load, it might be a flyback diode.  If you remove the power from an inductive load it will generate a voltage in the opposite direction. A flyback diode will allow that surge to be dissipated. Otherwise it will blow up your transistor.
Offline Nusa
« Reply #2 on: December 23, 2019, 04:50:10 pm »
Generally it's there to protect the transistor from feedback. In some transistors, it's integrated in the transistor package.
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #3 on: December 23, 2019, 05:36:22 pm »
If the base-collector junction becomes forward biased by a difference in the collector voltage and vid the diode will turn on preferentially since it has no external series resistance and prevent and significant current flow in the base-collector junction.  However since the entire circuit is not show it may be there for other reasons.
« Last Edit: December 23, 2019, 05:39:57 pm by graybeard »
« Reply #4 on: December 23, 2019, 10:16:56 pm »
I unfortunately do not have the schematic for the circuit this output supplies.
The input of the circuit that the VDD output goes to begins with several resistors. I believe to be essentially voltage dividers, so essentially a resistive load.
