The vast majority of electrolytic caps are rated for at least -40°C, how they are supposed to fail in your test?
Vast majority of
quality caps, yes, definitely. The whatever-"brand" ones used in cost-cut supplies? I don't think so.
The equivalent series resistance did not recover, and capacitance dropped; the switcher fails to oscillate. I don't have the equipment to quantify the changes, though. I suspect some kind of chemical change in the electrolyte, perhaps crystal formation leading to conductive tendril formation. Basically, poor quality electrolyte failing at low temperatures.
That said, I could be wrong, absolutely! Like I said, electronics without caps, batteries or LCDs have survived several winters in the same outdoors-temperature but weather-shielded shed cupboard without observable issues, so I'm making informed guesses (by a materials physicist specialized in molecular simulations) at best. I mean, practical knowledge beats theoretical musings every day.
And what it has to do with operation temperature?
I thought it explains why I don't trust wall warts to survive freezing. I would never trust those cheap Goobay wall warts to not catch fire in freezing temperatures, for example.
Many different stores here (not part of the same chain or ownership) sell 'Enjoy' brand 12V 2A IP44 rated outdoors power supplies with -40°C ~ 85°C operational temperature range for 20€-25€, marketed to work with several different brands of cameras and LED lights even in reputable electronics stores like Verkkokauppa, so I am willing to trust them. (Based on reports from others running the same camera, it works fine from 12V without overheating.)
Its own 9V 0.85A 100-240VAC wall wart is marked
TO90085-2C1 (manual states
T090085-2B1), and seems absolutely tiny (albeit not "too" light); I definitely don't trust it, having watched DiodeGoneWild and BigClive teardowns of such. The Finnish sellers note that this has a 3m long DC cable, because you need to place the 9V wall wart indoors. It has a CEE 7/16 plug, so IP20 rated at best. The camera itself, according to its
datasheet, is IP66 rated when mounted, with -30°C ~ 60°C (-22°F ~ 140°F) operational temperature range.
I have designed and build circuits which operated down to liquid nitrogen temperatures. I qualified parts including ICs for operation at such a low temperature.
Oo, that's about -196°C (77 K). Impressive!
I used solid tantalum capacitors without problems. Transistor gain is lower at low temperatures. This may cause oscillator circuits to not oscillate.
Right.
In practice, PoE voltage on the cables is in the 40V to 57V range, and powered devices like these cameras need to use a switchmode DC-DC converter to get to 12V. It is exactly the malfunction of the converter in low temperatures, either not working, working intermittently, or causing a voltage spike exceeding the safe input range, and eventually breaking the camera when I'm not there to investigate, that I want to avoid. It is also the main reason why I so like the idea of adding a linear regulator at the camera power connector.
there's dc-dc converters that are rated for -40c or even lower
Mouser sells tiny (23mm×15mm×14mm) Silvertel Ag9912MTB IEEE 802.3af Class 0 modules for about 9€ in singles (
link), outputting 12V 1A (12W), requiring 42V ~ 57V at startup, 36V ~ 57V during normal operation. These are rated for -40°C ~ 85°C operating temperature, and require very few additional components (see attached diagram) to make a fully-featured industrial IEEE 802.3af 12V 1A PoE splitter or powered device. A single resistor can adjust the output between 10.0V and 12.75V.
It does need a 100mA minimum load for stable noiseless operation, but in my case an external 120Ω 2-5W resistor (or four 470Ω in parallel) in parallel with the camera is quite acceptable. A better solution would use a power N-channel MOSFET controlled by an instrumentation amplifier over a 0.1Ω shunt resistor, so that without any output load, the MOSFET would dissipate 1.2W. When the voltage drop over the shunt resistor exceeds 10mV, it would be fully conductive. Between these, it should be roughly linear, ensuring a constant 1.2W minimum load.
If built in to the camera, none of this would be needed, so designing this in from the get go would make much more sense.
I think that if one adds both the suggested CLC filter and a linear regulator to 9V or 10V, you'd get pretty nice low-noise 1A supply out of it, too, for other applications.
Thus, a valid DIY solution from reputable sources like Mouser/Digikey etc. is available to anyone with sufficient skills. I'm not sure I myself am there yet, though.
