Hello everyone,
I pulled some LM13700 OTAs from an old board and tested them. All voltages, currents, and resistances were measured. I had the expected (approximate) voltage gain using the equation A=(R2/(R1+R2))∗gm∗RL where gm equals 19.2∗Iabc.
The problem begins when I use the linearizing diode on pins 2 or 15. The gain goes down substantially, the higher the current (lower resistor values) on these pins, the lower the output. I have used Marston’s equation from the old Nuts and Volts article, Iout=2∗IS∗(Ibias/ID) but the result are way off.
Does anyone know of a better way to calculate gain in an LM13700 when the linearizing diodes are used?
UPDATE - I just received some new LM13700's and got the same results.
