Author Topic: Garage door wall control communication  (Read 2185 times)
Offline joegtpTopic starter
« on: October 22, 2013, 03:39:06 am »
I've been trying to figure put how my garage door wall control communicates with the motor. It's definitely bidirectional because it can display sensor status. What I find puzzling is that there are only two wires going from the wall control and the motor box. I guess it could be RF but that seems strange since it has a lock out button as well.
Offline David_AVD
Re: Garage door wall control communication
« Reply #1 on: October 22, 2013, 08:46:26 am »
Low voltage DC with the data modulating the power would be my guess.
Offline amyk
« Reply #2 on: October 22, 2013, 10:04:29 am »
Should be rather easier to figure out if you can take it apart...
« Reply #3 on: October 22, 2013, 07:36:01 pm »
Simplest is to use a set of resistors switched to show the various functions in the box, and provide a constant current down the wire that drives a LED for status, with the current being lowered to indicate a fault. Other method is to modulate the data over the wires and have a micro inside the remote side that reads the supply voltage to get data and pulses the line to a low level to send data back.
