Hello,
For some scientific stuff, I have to build a high voltage pulse generator (from hundreds of volts to kV), able to generate very quick pulse (5-20ns) into small a small inductive load (estimated between 15 and 300nH).
The architecture is based on a flyback boost converter charging a bank of ceramic capacitors. A very fast MOS triggered by an external trigger closes the circuit, discharging the capacitors into the load. I have already build some (dirty) prototypes using Si-MOS. I'm now looking for a GaN MOS.
I'm concentrating on the block driver+MOS+cap+load. As a first step, I'm simulating the ideal circuit, omitting parasitic trace inductance.
I have a strange behavior on the drain : depending of the voltage of the capacitors bank, it may - or not - clamp the drain to the source (and therefore, the ground).
Simulation, 50V : output pulse is ok
Simulation, 200V : output pulse is narrowed and Vd low level is not ground.
Simulation, 500V : output pulse is narrower, strange step effect. Carefully look at Vd low level : it never goes to 0.
Simulation, 200V, 3 MOS in // : output pulse is ok
When replacing the L by a R, the output pulse is good. I thinking to a L/Coss resonance effect or something like that. I'm not sure to understand the phenomena, and so not able to resolve it.
I have tested a quite different MOS from the same brand, result is quite the same.
If a analog guru read this, feel free to any advice
Thanks !
