Author Topic: Need help to understand hydrophone specs  (Read 2028 times)
Offline Alexei.PolkhanovTopic starter
« on: July 08, 2015, 07:05:23 pm »
I found a hydrophone unit that appears to be of very good performance, but then I looked at specs I see this:
Receiving Sensitivity ( at 1 kHz ) ............................... 115 +/- 2 dB rel 1 pC / 1 uPa
I am really unsure how to interpret it. I expected sensitivity to be a negative value in Db. as V/uPa but instead I see a positive Db value with 1pC/1uPa. What is pC ?
How can I convert it to V/uPa?
Offline fcb
    • Electron Plus
Re: Need help to understand hydrophone specs
« Reply #1 on: July 08, 2015, 08:43:43 pm »
I agree, it looks like it needs more context.  Can you link to the datasheet?
Offline ConKbot
« Reply #2 on: July 08, 2015, 09:05:49 pm »
PicoCoulomb, its a charge output transducer, but I agree that that is an odd value, cant really make sense of it in my head either.
« Reply #3 on: July 08, 2015, 09:26:44 pm »
link: http://www.ebay.com/itm/181769482491?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
No datasheet anywhere.
I found it, finally ... ufffff ... in some small old scanned paper from 1970s entitled "calibration of hydrophones".
pC stands for "charge sensitivity" and it is written as 1pC/uPa.
Sq = Sv * (Capacitance of hydrophone + Cable)
where Sq is a charge sensitivity and Sv is voltage sensitivity (V/uPa).
So in my case value 115 Db 1pC/uPa can be translated as V/uPa in dB
10*log10( 10^(115/10) / (11500e-12+1500e-12)) which is equal to 193.86 dB 1V/uPa. Huray!!! unless I made mistake somewhere  ???
Capacity was also given in small spec sheet that I have:
Capacity at  20 °C ....   ( at 1 kHz )   .............................. 11500 pF +/- 1500 pF
I ignore the cable because spec is for hydrophone without the cable.
193 dB is not bad but not exciting. I found few at 209-216 dB at similar prices.
« Reply #4 on: July 09, 2015, 12:17:09 am »
Yes, you right pC it is picocoulomb - with relation to "charge sensitivity" it all make sense now!
