I completely agree. I was baffled as I read the LONG description. What would make someone devise the proposed multitone solution to the problem?
> A mobile can vote between 3 or 4 receivers in ONE second -NO packet system is that fast.
So the data needs to be sent at least at a 1 Hz rate. 16 bits every 1 second.
Try 10 "updates" per second - 10 Baud per "carrier".
Bill
ok, so 10x that. How would I transmit 160 bits/sec? Simplest things I can think of are OOK and FSK. As mentioned before, all that is needed here is a parallel to serial converter. What I have lying around are Arduino Pro Minis, just the ticket. 17 completely undedicated digital I/Os (PORTB 0-4, PORTC 0-5, PORTD 2-7). If you need more you can use the RESET line, XTAL (PORTB 6-7 and use internal 8MHZ RC) PORTB 5 (LED) and TX/RX (PORTD 0-1), but I'm going to use the Tx/Rx. I won't even have to touch the Arduinos. All I need is one resistor.
Coded u_tx.c just to generate numbers and throw them out the UART at 600 baud. Yes, for 16 bit packets I'd have some frame byte and two data bytes, but I'm just showing the concept. Hooked the ATmega Tx UART output through a resitor to the FM modulation port of my signal generator set for 500 MHz, 5 kHz peak deviation.
For the receiver, I hauled out my modulation analyzer. Set for FM demod, 75usec de-emphasis, 3kHz lowpass. Fed the modulation output directly into the Rx UART pin of another Arduino Pro Mini running u_rx.c. All the code does is take the UART Rx input, and send it out the UART Tx so I can see it on my PC.
Picture shows setup. Both ATmegas are on a single small solderless breadboad sitting on my laptop keyboard. Square wave FSK input of sig gen is shown on scope as well as Modulation Analyzer demod output. PC is running a terminal program that shows sequential numbers being received.
For the simple code, I use Arduino hardware and the gcc and avrdude that gets installed with the Arduino install, but I ditch the Arduino UI and use the avr libraries. I call gcc and avrdude from the command line.
