Author Topic: Cable labels for little wires  (Read 1904 times)
Offline jeremyTopic starter
« on: November 05, 2014, 01:16:16 pm »
Hi all,
I build a lot of one-off devices (often on vero), and I'm looking for a good way to label individual wires. I would also like to do it to label wires on my logic analyser so I don't forget which signal is which ;) . Unfortunately, most cable labels are for just that, cables. I'm talking about labelling breadboard sized wires aka AWG 20-24. Has anyone tried to do this before? Or alternatively, do you think the standard office labeller would be good enough?
Offline peter.mcnair
    • analog-ontology
Re: Cable labels for little wires
« Reply #1 on: November 05, 2014, 02:16:43 pm »
I've used RS heat shrink 3 mm internal diameter cable markers for small (7/0.2 about 1.2 mm overall diameter) wires. They shrink small enough to stay put.
Interestingly, the letter Y is the cheapest.
 (e.g. RS 392-747 Heatshrink cable marker ' Y',3mm i/d)
Offline ElektroQuark
    • ElektroQuark
« Reply #2 on: November 05, 2014, 03:32:42 pm »
I have a little entry in my blog about this: CLICK!
It's in Spanish, but with many images, easy to understand.
« Last Edit: November 05, 2014, 04:19:06 pm by EdoNork »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: November 05, 2014, 03:51:19 pm »
For really small wires, get some small white heatshrink, mark with a fine permament marker before shrinking, and then shrink - the writing will shrink with the sleeving
Day Job: Mostly LEDs
« Reply #4 on: November 05, 2014, 09:03:05 pm »
Ah perfect, thanks guys. This is exactly what I was looking for.
