Author Topic: Does anyone know what screw this is?  (Read 4449 times)
Offline LeWidgetTopic starter
« on: April 02, 2014, 08:10:15 am »
Hey guys,
I'm trying to find out the details of this screw that came out of a Logitech Z-5450 speaker. I've been to a couple of stores (bunnings & other tool stores) but they weren't sure :\.
details are, (NOTE: the screw in the diagram with the measurements is a different screw. Im just using it as reference.) :)
So far, I think i've only narrowed it down to a 'Pan Head' screw with a Phillips head slot in the top.
I'm not exactly sure how to find out the specs of the threads though :\. If anyone could post some tips or info, that would be super :)
« Last Edit: April 02, 2014, 02:56:42 pm by LeWidget »
Offline Kjelt
Re: Does anyone know what screw this is?
« Reply #1 on: April 02, 2014, 08:13:31 am »
In dutch we call this a 3x10 platkop schroef, free translation: 3x10 flathead screw.
But it probably is a parker screw (selftapping metal screw).
Online johansen
« Reply #2 on: April 02, 2014, 08:13:49 am »
if i really needed to find a replacement i would find some drywall screws and cut them to the right length. (and the head to the right diameter)
no clue what that thread profile is called though.
Offline Kjelt
« Reply #3 on: April 02, 2014, 08:17:59 am »
Correction they call it a plate screw here:
Kelfort plaatschr.ev ck 2.9x9.5 Din7981ch  think thats the one, see link below  articlenr: 5514408
http://www.breur.nl/catalogsearch/result/?q=5514408+
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: April 02, 2014, 08:19:37 am »
There are some screws specifically designed for plastics. which have a slightly different thread profile to normal selftapping screws
http://www.aspltd.co.uk/screws-for-plastics.php
Day Job: Mostly LEDs
Tac Eht Xilef
  • Guest
« Reply #5 on: April 02, 2014, 09:01:38 am »
Doesn't look like a panhead to me, though it's a bit hard to tell - it looks like a metric 3mm x 10 (or #4 x 3/8"), dome head, metal or plastic self tapper.
A domehead is less like a flat top with rounded shoulders and more like a roundhead that's been flattened on top  ;)
« Last Edit: April 02, 2014, 09:04:38 am by Tac Eht Xilef »
Offline EEVblog
« Reply #6 on: April 02, 2014, 09:19:38 am »
Those plastic screws are also called "Tri-Lobe"
The screw you have looks to be pretty standard pan head, you can get them here:
http://www.smallparts.com.au/store/partscombined/selftappingscrewsforplastics/
« Reply #7 on: April 02, 2014, 01:09:55 pm »
Hey, thanks guys for all the feedback :)
Looks like the link 'EEVblog' put up, looks like them. Now, just need to find the appropriate thread type/gauge. (I sent through an email, will see what they say)
Thanks again guys :)
« Reply #8 on: April 02, 2014, 01:14:34 pm »
Tri-lobe is one sort of special screw, which has a slightly triangular profile. There is also a type which looks like a normal self-tapper but with a deeper thread profile
« Last Edit: April 02, 2014, 02:47:18 pm by mikeselectricstuff »
