Author Topic: GL823 sd card reader, no response  (Read 3917 times)
Offline martin321
  • Country: no
« on: November 28, 2015, 04:50:40 pm »
I am trying to get the GL823 card reader to work, but there is no response from the pcb when I plug in the USB cable.
There is 3.3v DVDD, 1.5v on LED pin and nothing on PMOS or AVDD.
No resistors placed at R1 to R5.
Received the design guide and datasheet from supplier. Think I have correctly copied it.
gl823_sch.pdf is the one I have made.
If anyone could help me out I would relay appreciate it.
Martin
Offline martin321
  • Country: no
Re: GL823 sd card reader, no response
« Reply #1 on: December 07, 2015, 06:52:38 am »
Found the post linked under. Anyone that can see my error?
https://www.eevblog.com/forum/beginners/issues-with-breadboard-sd-card-reader/
Offline mich41
« Reply #2 on: December 08, 2015, 01:37:04 pm »
Hint: where the power to AVDD is supposed to come from? :)
Offline martin321
  • Country: no
« Reply #3 on: December 08, 2015, 04:21:09 pm »
Sorry, but I don't follow you.
Online wraper
  • Country: lv
« Reply #4 on: December 08, 2015, 04:32:58 pm »
Do you expect AVDD to appear from nowhere  :palm:? It is externally connected to the chip. On the gl823_sch.pdf through the L1 inductor from the DVDD.
« Last Edit: December 08, 2015, 04:35:46 pm by wraper »
Offline mich41
« Reply #5 on: December 08, 2015, 04:59:40 pm »
Well, DVDD does appear out of nowhere, so go figure :box:
Seriously though, page 16 of the datasheet kinda suggests that the internal 3.3V regulator outputs to DVDD and then note1 on page 12 tells that AVDD needs to be hooked up to that through a bead.
