Hmm I wonder what the failure mode on that probe will be after its been overloaded too many times.
Descriptions of VHF megaoverloads are kind of scary, it seems to vaporize stuff.
I wonder if a megaohm meter would pick up any damage to dielectric from overloading. I guess the voltage is not that high at 100v, but it might be prudent to attempt monitoring
could it spot polarize the dielectric?
I think it would blow a hole some where when it finally decides to fail, possibly in a thinner area or area of minor impedance mismatch? I.e. slightly different braid distribution, surface conductivity, etc. Some where along the transmission line you have a higher voltage.
I think dielectric failure has something to do with polarization, it seems to be what happens to dielectrics under high voltage. Thermal effects are weird to think about for very fast signals, but I think it might get hotter somewhere too.
Someone might be able to leave a EFT machine running continuously on a cable
Would the foam start to densify in some spots? Or maybe become brittle? Mechanical properties of polarized materials might be interesting to read about. I think it would become brittle and then electrostriction would wear it more and more (cracking) until it broke through. I am thinking electrostriction on a soft dielectric might be similar to a dog tugging on a rope chew toy. Fans of basketball shorts might notice how the nylon rope (built in belt) begins to behave after alot of wear and tear, the nylon seems to grow together making for very tough knots. Given that alot of coaxial cables have foam dielectric, I expect they might not fair well to overload. The sponges, particularly the ones backed with scotch brite (which is kind of like the stiff coaxial cable wall), even seem to spall for some reason, like chunks fall off the bottom with alot of use.
and failure modes of foam slippers.
Also makes me wonder about ultrasound testing of coaxial cables.
