Hey there
I have a noise issue on my device, and I would love to hear your thoughts
The device is 5V USB powered, and the noise comes from an LED display (which is PWM'ed).
I think the issue is coming from a GND loop, or more exactly ground currents not going where they are supposed to. It's my analysis but I am not 100% sure.
Basically the display creates voltage noise on the 5V supply, which is fully sorted, so that's not an issue. But it makes sense that the return currents (i.e. GND) have the same noise, which is not a problem either when these currents go through the USB connector's GND.
Problems start to arise when I have another connector on the board, which gives another path for these return currents. See image:
(note: I guess the red arrow on the top right is either very small or not existent, since most currents will go back to the source which is the laptop / wall plug on the left)
There is a big difference from one audio equipment to another, whether this noise on GND is hearable or not. On some you cannot hear a single thing, on others it is very obvious.
The solutions I found so far are:
- Telling the users to avoid this type of wiring (i.e. use a separate wall plug for the device)
- Removing the noise by not PWM'ing the display -> a big change on PCB/electronics, and it would require another display
- Taming the noise by putting a 470uF cap in front of it -> difficult to do because of the USB in-rush current limitation, also that does not get rid of the noise completely
- Somehow avoiding connecting the ground on the Jacks -> unfortunately this is not possible on one of the jacks since the signal is single-ended and needs a reference
As usual I am using this forum both to hear your opinions and ideas, but also as a self-reflexion board
(also this could be useful to people in the future having similar issues)
Thanks!
Simon
