Better use some heavy copper plate like this:
Or you can solder additional copper strips onto the PCB:
While I was impressed with your handiwork there
I can foresee a cascading failure should one of those MOSFETs experience an overcurrent situation (or other failure), and the thick traces
DON'T blow. You'll blow the skinny legs off one MOSFET, and the load moves to the remaining MOSFETs which now have more current to handle, and might cause another skinny leg to blow, and so on..... until all the FETs blow their legs, (or blow up) but your thick traces hold strong.
Wouldn't it be better and cheaper (less copper) and safer for your FETs, to limit the current to SAFE operating levels, and also fuse it or breaker it above that point, just in case? I'd rather change a fuse or reset a breaker on the outside of the box, than to dig into the enclosure to replace a FET.
I admit I have never had the chance to design anything that operates above 10A, but this is what I would be thinking about to design something that can handle a 200A stall load.
