Author Topic: Rant: D Connectors  (Read 2576 times)
Offline German_EE
Rant: D Connectors
« on: June 18, 2017, 03:25:01 pm »
The situation with D connectors really bugs me. Most of the world (including the IC manufacturers) live in a 0.1 inch x 0.1 inch world and everything fits in here from displays and chips to a large number of connectors. Not the D type though, that second row of pins offset from the first means that you have to either make your own PCB or use an adapter. When making a PCB mounted socket or plug it would have been just as easy to make the pins on a 0.1 x 0.1 grid, just bend the wires a bit, but they just couldn't do it.
OK, rant over, I have 12 holes to drill between the existing holes on a piece of perfboard.
Warren Buffett
Online Alex Eisenhut
  • If you can buy it for 4$ on eBay, why design it?*
Re: Rant: D Connectors
« Reply #1 on: June 18, 2017, 03:26:44 pm »
That's why you use an IDC connector that uses ribbon cable to go to the board, perfectly fine grid there.
*Except AC/DC adapters on eBay. Avoid them all!
Offline Gyro
« Reply #2 on: June 18, 2017, 03:33:08 pm »
If you can put up with mounting the D-sub connector at the edge of the board, then you can solder one row and hand wire the other one. I've done it for small RS-232 adaptors in the past. Just a thought.
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline N2IXK
« Reply #3 on: June 18, 2017, 06:53:53 pm »
The D-subminiature connector line dates back to 1952, well before the DIP package that ushered in the 0.1" grid standard.
Not sure why you would expect it to conform to a standard that didn't yet exist...
"My favorite programming language is...SOLDER!"--Robert A. Pease
The following users thanked this post: fourtytwo42
Offline floobydust
« Reply #4 on: June 18, 2017, 07:32:16 pm »
So you prefer micro-USB? SNAP BREAK BUST FAIL
The following users thanked this post: Electro Detective
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: June 18, 2017, 07:56:50 pm »
Centronics style connectors have arbitrary dimensions.  GPIB for instance isn't apparently metric or imperial, it's just odd.
Doesn't matter when you've got PCBs.  Doing perf board?  Put it on pigtails... :-//
Seven Transistor Labs, LLC
Online Someone
« Reply #6 on: June 19, 2017, 01:58:40 am »
No, the world has moved on from those days. Metric is now driving pin pitches 0.7, 0.5, 0.4mm so on and through hole is disappearing rapidly.
Offline DBecker
« Reply #7 on: June 19, 2017, 04:58:09 am »
I think that the original poster's point was that the PCB footprint doesn't necessarily need to match the connection pin pitch.  It would be useful to have a D-shell connector that has a 0.1" footprint.
The following users thanked this post: Jacon
Offline Vtile
  • Ingineer
« Reply #8 on: June 19, 2017, 08:49:45 pm »
Long live D-sub.  :)
Offline Andreas
« Reply #9 on: June 19, 2017, 09:10:15 pm »
Hello,
I cannot complain: My D-Subs fit. Always.
with best regards
Andreas
The following users thanked this post: Someone, Smokey, Electro Detective
Offline viperidae
« Reply #10 on: June 20, 2017, 06:47:54 am »
RJ11/12/45 sockets are the same, two rows of offset pins that won't fit a perf board.
Offline TheUnnamedNewbie
« Reply #11 on: June 20, 2017, 08:28:39 am »
I think the flawed assumption here is that the potential advantage of having a connector (or anything really) fit a .1" perfboard outweight all the other advantages of not having it fit - like how easy it is to route on an actual pcb, strength, density, etc.
Also, most manufacturers no longer live in a imperial-driven world. The only things really still imperial (but actually it's not) is SMD footprints like the typical "1206, 0805, 0603, 0402" (even though I believe they are actually defined in metric and then translated to imperial to match, with a 0402 actually being 1.000mm long and 0.500mm wide). In fact, I usually get annoyed by the old DIP footprints and headers not fitting nicely on my metric grid PCBs, making nice allignment a PITA.
The best part about magic is when it stops being magic and becomes science instead
