Author Topic: Part number for those cheap 3x6mm 2-pin SMD tact switches  (Read 950 times)
Offline HSPalmTopic starter
  • Country: no
« on: August 09, 2016, 01:15:25 pm »
On many products I buy I find the same type of SMD tactile switch. It looks like the "regular"one, only cut in half. But I can't find anything similar on Digikey or mouser.
On aliexpress and ebay they can be found as "3x6 smd switch", in different heights. Here's a couple examples:
http://www.aliexpress.com/item/3-6-2-5MM-3x6-SMD-Tact-Switch-imported-red-button-2-feet/32708221611.html
http://www.aliexpress.com/item/1000pcs-lot-3-6-4-3MM-touch-switch-white-SMD-2-feet-micro-switch-limit-switch/32336213908.html
I want a switch I can have my chinese manufacturer source for cheap, and also an alternative at digikey/mouser when/if producing locally.
I am interesten in part numbers, datasheets and compatible parts.
  • Country: no
