Author Topic: graphic equalizer with gyrator issue TL072  (Read 871 times)
Offline dave_j_fanTopic starter
  • Country: in
« on: August 22, 2020, 02:56:58 pm »
this is an equalizer with gyrator elements.
i have tried to realize it with Tl072
opamp.
i made just for 60hz
how to connect it on 15 0 -15v
so far i have not been able to get clear audio via this.also pot for 60hz filter dont show any change when i vary.
Online ledtester
Re: graphic equalizer with gyrator issue TL072
« Reply #1 on: August 22, 2020, 03:31:51 pm »
Here's an article describing the circuit:
http://www.geofex.com/Article_Folders/EQs/paramet.htm
Note that in the other schematics Vb is defined by a voltage divider between +9 and GND:
1051572-0
So for adaptation for 15-0-15 I would use 15 for "+9", -15 for "GND" and 0 for "Vb".
The following users thanked this post: dave_j_fan
  • Country: in
« Reply #2 on: August 22, 2020, 06:05:49 pm »
ok .thank u for very accurate reply.
i will try the same
