Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Anybody that can give some input on voltage detector for lawn automover?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Anybody that can give some input on voltage detector for lawn automover? (Read 1847 times)
Tony.T
Regular Contributor
Country:
I want to live in theory, everything works there!
on:
May 17, 2017, 08:04:02 am »
I have a Husqvarna automover for my lawn. Want to build a detector for the cables in the ground.
Anybody that can point out a schematic for it? What will work for this purpose?
thanks.
Logged
Rerouter
Super Contributor
Country:
Question Everything... Except This Statement
Re: Anybody that can give some input on voltage detector for lawn automover?
Reply #1 on:
May 17, 2017, 08:21:52 am »
Is this to prevent you from hitting cables, or to follow a route via a buried cable?
If the first, do you have access to the wiring to injlect a signal?, do you only want to detect mains, or telecom aswell
Logged
Tony.T
Regular Contributor
Country:
Reply #2 on:
May 17, 2017, 11:30:22 am »
It's just to find exactly where it is on the lawn... If one needs to dig..
I have access to the cables to insert voltage if necessary.
Logged
jeroen79
Frequent Contributor
Reply #3 on:
May 17, 2017, 11:53:39 am »
So what is the role of the lawnmower?
It only works on the surface and shouldn't hit anything buried below it.
What sort of cables are you looking for?
Just mains?
Can you access both ends of these cables?
Logged
Tony.T
Regular Contributor
Country:
Reply #4 on:
May 17, 2017, 04:01:12 pm »
Yes...i can access both ends. Today the lawnmover can itself detect the cable in the ground, and bounces back and changes the direction to continue cutting the grass another direction. But if i want to dig some hole in the ground i need to be able to detect it by myself. Just want to avoid cutting the cable and kill the functionality. But even if i can access both ends i do not want to disconnect the charge station where all the wires are connected to and then insert higher voltage. I just want to be able to detect the wires when in operation...just as the lawnmover does...
https://youtu.be/k4etAYu9rc8?t=9m25s
my wires are not visible its under the ground.
Logged
jeroen79
Reply #5 on:
May 17, 2017, 04:37:58 pm »
So the cables in question are the mower's boundary wires?
Can't you just make the mower run over a spot you where want to dig and see if it continues to drive over the spot or changes direction?
If you want to make some sort of handheld sensor you should investigate what the base station does with the wires.
What voltage and current can you measure? What about frequency/waveform/dutycycle?
If you open up the mower, can you identify the sensor?
If so, what can you measure around it?
You could temporarily connect a short run of above ground wire for testing.
Logged
David Chamberlain
Regular Contributor
Reply #6 on:
May 17, 2017, 05:25:47 pm »
Came here to see a device that could automatically move my lawn and was disappointed, now I'll have to do it myself.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
