Electronics => Projects, Designs, and Technical Stuff => Topic started by: bug13 on March 07, 2016, 07:55:31 pm
Hi guys
I am looking for a solution to detect ground loop. I came cross this one:
http://www.loopslooth.com/how%20to%20find%20ground%20loop.html (http://www.loopslooth.com/how%20to%20find%20ground%20loop.html)
Have anyone use this? or try something like this? I think it will work, but how well it work?
Thanks guys
Our electricians have used an industrial versions to find ground faults like these;
http://www.multi-tech-industries.com/gfault.html (http://www.multi-tech-industries.com/gfault.html)
http://www.eepowersolutions.com/categories/ground-fault-monitoring-detection/?gclid=Cj0KEQiAvJS3BRDd44fjndyii6MBEiQAN4EkPQi9NJyOXubaawHSHBjAL4KhKGxImgeT3vulUhNce64aAvDJ8P8HAQ (http://www.eepowersolutions.com/categories/ground-fault-monitoring-detection/?gclid=Cj0KEQiAvJS3BRDd44fjndyii6MBEiQAN4EkPQi9NJyOXubaawHSHBjAL4KhKGxImgeT3vulUhNce64aAvDJ8P8HAQ)
I would see if an electrical test equipment dealer would loan or demo it for you.
It can be a difficult task depending how crowded and buried with other cabling is the circuit you are trying to trace.
Good luck
