Hello everyone!
I am currently working on designing my own soldering iron controller for the JBC C245 handle. One thing I am confused about, and can't seem to find too much information about, is grounding for devices like these.
My plan is to use a dual 24VAC secondary transformer to power the logic and iron. One secondary will be rectified and regulated to 3.3V for the STM32F3 microcontroller and other logic. The other secondary will just be fused and switched to the iron. However, I also need to sample the thermocouple that is built into the iron cartridge.
I know that when I actually build the thing, the AC input has Earth, neutral, and hot. My question is, what is the safest way to configure the earth/ground/chassis connections for safety and noise performance? I am assuming that you definitely connect the chassis to earth...
One secondary will be connected (switched) directly to the C245 handle. Assuming the attached schematic is correct for the connections for the soldering cartridges, I can then just connect one side of the secondary to ground and then the other to the middle contact of the cartridge to drive the heater. Then, the thermocouple is also ground referenced... Or do I connect one side of the secondary to Earth?
The other secondary is rectified and regulated to 3.3V for the microcontroller and other logic. I am simply grounding at the output of the full bridge rectifier... However, since the heater is connected via a completely separate secondary, I am not sure what implications this has for reading the thermocouple. How can I guarantee that I do not exceed the common mode range of my instrumentation amplifier?
Do I connect earth/chassis to ground via some high impedance? That is what I often see in other designs.
Sorry for so many questions. As you can see I am quite confused
Any pointers would be greatly appreciated.
