Hi
I have a compound device with an Avalanche Photodiode (3 external pins) and a separate RDT-based temperature measurement with I2C interface (4 pins: Vcc, GND, clock, data). I do not want to use the temperature measurement function at the moment. I plan to ground the clock. Data should probably be connected to ground through a 10k resistor, but does it make sense to ground Vcc? If so, should it be shorted to ground or connected through a resistor?
Or should Vcc be left floating?
Thanks
Cicada.
