Good evening everyone,
my name is Gonzalo, I´m a mechanical engineer and I come here looking for answers to a couple of questions.
What Im needing is a system that can read RFID tags, store data from when that tag has been read, and then send via GSM/Wifi all the aqcuired data to a server in the cloud.
This will be used in cows, and retrieve data of the behaviour.
Other needs for the project are.
- Low battery consumption. It will be running on batteries, and battery replacement will not be an easy task.
- I guess it might not have GSM signal sometimes, so all of the data should be stored for later sending when GSM signal is up again.
- Data sent should not be doubled. After data is uploaded in the server it should be allowed to be erased from the transmitter. This in order to not let any of the data be lost.
The question is, how would you face this? Using an esp mcu and sim800l? As this should have power saving features the system should be woken up whenever a read has to be taken.
Since I also do not know how to code I´ll be passing all this info to someone that actually can. Idk, maybe even make it a collaborative project. Where can this be done?
Thanks!,
Gonzalo.
