Thanks for the explanations.
Yeah, well, I know that there is some voodoo in the world of musicians. Those guitar amp things, though, have been demonstrated to me. It's not totally voodoo. I'm not saying that it's categorically impossible to get the same results in different ways which may be more efficient.
But it was the case until very recently, though. 10 Years ago, amp modellers produced brittle, broken, absolutely horrible sounds for what musicians call "high gain sounds", i.e. multi stage distortion / compression etc, in the rather peculiar way that tube amps design for the heavier kind of music do. The digital modellers anyway - some analog modelling circuits, like the Peavey ones, sounded quite good already. This has improved recently, but it's not surprizing that not everyone is jumping aboard immediately.
And I don't want to buy a Kemper profiling amp, I just want to build my little, for the start anyway, minimalistic amp, modelling some of the aspects of such tube amps.
I did find circuits for the typical preamps of that sort. So I just wanted to also make a power amp which interacts with a guitar speaker, which is not a full range HIFI speaker, but typically one with a peculiar response, in the typical way that such tube amps interacted with it - but with solid state circuits, and for low wattage.
Which is why I was intrigued by those pages linked earlier.
I have found a circuit which uses a TDA 2003, configured for current-driving (and not attempting soft clipping).
The soft clipping thing... well I figured it would be a natural seeming way of protecting the stuff from blowing the speaker or my ears, in a not abrupt emergency shutdown way or how ever one would normally do such things. Nnot with a hard threshold, and actually in a way that a musician can playfully interact with it, like they have been doing for decades.
But I guess I would be fine with some simpler but effective kind of protection circuitry, if the preamp circuits by themselves sound good enough.
What would such overloading protection look like?
Or is using a TDA 2003 by itself protection enough? It has some internal protection, other than the 2002. And I have some laying around. (not from clipping and bombarding the speaker with too much higher spectrum end energy, though? Which the soft clipping was supposed to solve - I know you use a HIFI amp only maybe 1/2 cranked up, but that's not what you do with a guitar amp, it's just weird, especially if you have a 2...5W one or so
Maybe the 30W speaker can stomach a hard clipped 5W signal, but my ears, I'm not so sure.
I wonder whether the circuit on that black page, where you said "too many erros, forget about it"
would be a solution...
where he had a high valued electrolytic cap (ripple filter), followed by a big resistor, then another big cap. When there is an increased power draw due to e.g. clipped signal, the caps after the resistor would be emptied quickly (I imagine, if all is dimensioned correctly) and the resistor would limit how fast they get filled again, so it would also limit the power that can be output for a longer while.
Seems primitive, but would that do that job?
