I really just don't want to have to touch any 240v if i can get away with it!
If you want to be an electrical engineering student you should learn how to handle the mains safely. Running away from scary things doesn't help you in the long run.
What you could do to help you learn is to go for a two box solution. Get a mains transformer, e.g. 12-0-12 or 18-0-18 V, and put it in an enclosure by itself. Put an IEC socket on the mains side with a fuse and a switch and maybe a pilot light. Learn how to make crimped connections, and how to attach the ground wire to the case with a machine screw, ring terminal and shake-proof washer.
Install banana plug sockets on the low voltage side for your AC output. Get someone to check your work once it is all constructed. Now you have a safely enclosed low voltage AC power supply.
With this AC power supply you can freely experiment with various DC regulated supplies on separate boards or in separate enclosures and never worry about touching the mains. You can mix and match with different DC voltages, dual rail or single rail, just by swapping them in and out and using the same transformer to power them.
