Thanks dannyf,
Easy for you to say, but I don't have a thermometer that will measure the temperature v. resistance to calibrate things. Is it possible to find the temperature v. resistance of the Hakko 888d handle?
If I could get readings of just 50-deg C steps of temp I could interpolate the correct temperature with a MCU for any temperature setting.
I bought a cheap soldering station that works kinda like 6-day old Chinese take-out on a starving stomach, it has an LCD indicator that supposedly indicates temperature, but I don't think it knows up from down.
One thing I do now, with the Hakko handle running at full power, open-loop, it can easily remove an electrolytic radial through hole cap from a 4-6 layer table top PCB ground plane in less than 30-secs, the old station could never do that!
Maybe I can wrap the two handles together with a thin copper sheet and read the temperature of the older handle and write down the corresponding PTC Hakko resistance?
Now I might just try this elegant calibration technique, I got some sheet copper, just try to not burn my fingers, char my workbench and not burn down the house.
I have three readings so far:
21-deg C 59 ohms
Nice Lead/Tin 60/40 Soldering Temperature 100-110 ohms
Full Power Open Loop Nuke Meltdown 238 ohms
