Author Topic: Hall sensor A3144  (Read 225 times)
Offline rsfotoTopic starter
  • Country: mx
Hall sensor A3144
« on: November 27, 2024, 08:07:45 pm »
I found some A3144 in my boxes and wanted to test the behaviour. I wired it according to the following diagramm.
I read in the datasheet that the output can be as hi as the input voltage but my tests did not give me that value.
I powered it with 5V and with no magnet present it gave me ~1V and with a magnet close to it it raised to ~2V but not near the ~5V I was feeding.
Is the output dependent from how strong the magnet is?
Thanks Rainer
PD I do not know if those are really A3144 because the marking on the front is 743ZF and on the bottom it says +ALEA. Are those FAKE? or what are they?
« Last Edit: November 28, 2024, 10:15:39 pm by rsfoto »
Offline Shay
  • Country: il
Re: Hall sensor A3144
« Reply #1 on: November 27, 2024, 09:16:22 pm »
Thanks Rainer
PD I do not know if those are really A3144 because the marking oin the fron is 743ZF and on hte b ottom it says +ALEA. Are those FAKE? or what are they?
From the datasheet it seems like it is open collector. So you should either get ~0.2V to VCC.
Make sure that you have a 10K resistor, and try a different hall.
The following users thanked this post: rsfoto
Offline TimFox
« Reply #2 on: November 27, 2024, 09:53:57 pm »
That sensor, with open-collector output, is an active circuit (Schmitt trigger with hysteresis) driven from the Hall-effect element.
There would be a minimum value of magnetic field at the sensor to guarantee logic-1 (high) output.
Depending on the exact model  https://www.alldatasheet.com/datasheet-pdf/download/55095/ALLEGRO/A3144EU.html
the "operating" field value Bop is somewhere between 50 and 450 Gauss, and the "release" field value Brp is somewhere between 10 and 430 Gauss, with typical hysteresis between values of 55 Gauss.
Without a resistor on the output to +5V, the output will always be lowish.
