SSR ≠ analog switch IC. A solid state relay galvanically isolates the control side from the switched side. (Usually by using an optocoupler internally.) An analog switch does not.
In this case for sure I wanted a galvanic isolation for the input, and obviously I didn't necessarily need it for AC/DC. I just wanted to know if there are any obvious reason to choose one of the two, as to start.
Electromechanical relays for RF use have been around for along time & proper ones have been optimised for low through loss & high isolation.
This is why I went with this series, which should be good for the task, as shown in the comparison below (see pics).
There's a few ways these devices can introduce noise:
1. Johnson/thermal noise. White noise with spectral density equal to sqrt(4KTR), so easy to calculate from resistance and temperature. But I doubt this will contribute to overall noise unless the resistance is in the hundreds of ohms or more.
2. Flicker noise. Pink noise which will exist in analog switches or SSRs, but not in mechanical relays. I don't think datasheets will actually characterize flicker noise though.
3. Coupling from control circuits. Not really noise, but rather a path for noise from other circuits to contaminate the signal being switched. For example, parasitic capacitance from the relay coil driver to the contacts, or from the supply voltage of an analog switch to the channel. If your source and load impedance is very high, this might easily be the dominant noise source, but it's very unlikely that this information is characterized.
For 1 and 2 I think the mechanical relay is better. Also, if I recall correctly in a wideband configuration flicker noise should be secondary, but since I included afterwards an optional LP filter @ 1 kHz (in case I need to test a small DC signal) it may start to become influential, and using a mechanical relay should be a better option.
What I still don't get is why I keep finding information that say that SSR have in general lower noise (sorry, I know I'm not justifying the reasons, but it's my first time approaching these things).
According to the info I attached they should be pretty similar in that regard, and right now I'm thinking that maybe I could go with the LATCHING TYPE of this mechanical relay series, so to avoid whatever noise is generated in non-latching relays by keeping the coil de-energized for most of the time. In normal operation I am not expecting to change between CAL and INPUT, so unless I get major backslash could this be viable?
Oh, and obviously the cost also made me wonder if I could go with the SSR, since the mech relay is ~5-6 euros, while the DG419 is ~2 euros per piece.
In conclusion: I'd like to avoid two mech relays because of cost and size, but I feel like I'm risking it by using an SSR given all the possible noise sources; also, coupling seems similar if I got the correct graphs, but here I'm assuming that for the mech relay, for frequencies below ~5 MHz which are not shown the crosstalk becomes simply negligible, which is my main concern right now.
