Author Topic: Recommendations for Digital 100MHz dual channel oscilloscope  (Read 2510 times)
Online moffyTopic starter
« on: January 07, 2015, 11:10:02 pm »
I need to upgrade from an analog 20MHz scope to digital. Have between $600-$800AUD. What would you recommend and why? Thanks for the advice.
Offline Lightages
  • Canadian po
Re: Recommendations for Digital 100MHz dual channel oscilloscope
« Reply #1 on: January 08, 2015, 12:29:33 am »
There are quite a few recent threads relating to your question.
The most recommended right now is either the Rigol DS2072A for two channels or the Rigol DS1054Z and upgrade them.
« Reply #2 on: January 08, 2015, 12:49:06 am »
Thanks will look at them. Any apart from Rigol?
Offline Lightages
  • Canadian po
« Reply #3 on: January 08, 2015, 02:43:25 am »
I think in the price range you are looking at, there isn't much else to compete.
« Reply #4 on: January 11, 2015, 02:41:03 am »
Thanks for the advice. I went with the Rigol MSO1074Z. A bit out of my price range, but I think worth it for the larger screen and Logic Analyser. It is quite a steep learning curve from my old analogue scope.
Offline devanno
  • Old newbie
« Reply #5 on: January 11, 2015, 07:30:13 pm »
Include the Siglent SDS1102CML too.  The Rigol 1000z series is probably a touch above.  The Siglent can be had for about $356 US. (just checked on Amazon)  Look at some video reviews too, so you see the screen resolutions and differences.  I have the Siglent and have not put it through any heavy duty use, but it seems to work quite well for what I've done with it.  I have a Rigol DS2072A and it's a significantly nicer 'scope, but then, it's twice the price of the Siglent.
Free Electrons - Just one, please.
« Reply #6 on: January 12, 2015, 11:10:32 pm »
Thanks. My new scope broke yesterday, Channel BW LIMIT and INVERT soft buttons would not toggle. Rang my local supplier, Emona Instruments, and they sent a new update patch within 10 mins which fixed the problem. Nice to have good local supplier.
