Author Topic: ham radio  (Read 3538 times)
Offline House91320Topic starter
ham radio
« on: February 24, 2011, 07:06:38 am »
can you do time sharing with a ham radio anta
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
Re: ham radio
« Reply #1 on: February 24, 2011, 07:53:24 pm »
Er. What? Depends what you mean by time sharing.
Re: ham radio
« Reply #2 on: February 25, 2011, 06:10:18 am »
well if i wanded to share one atena between me and my dad lick an old main frame computer
Offline the_raptor
Re: ham radio
« Reply #3 on: February 25, 2011, 06:39:04 am »
Probably not unless you want to put a lot of money into developing a solution that would cost more than another antenna.
Antenna's aren't the expensive part of ham radio unless you are talking about huge towers.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: ham radio
« Reply #4 on: February 26, 2011, 03:29:04 am »
i'm having a hard time understanding the vocab. your dad lick an old computer with antenna? do you mean antenna?
Offline sonicj
  • updata successed!
Re: ham radio
« Reply #5 on: February 26, 2011, 01:07:56 pm »
a duplexer or a manually operated rf switch box. both are quite common and can be had on the cheap.
-sj
Offline Zad
Re: ham radio
« Reply #6 on: February 26, 2011, 04:34:05 pm »
Yes, if you want to share an antenna between 2 receivers that receive on the same band that the antenna is tuned to. Be aware that each receiver will only see half the signal. If either radio is a transmitter, expect the receive section on the other radio to burn out quite quickly.
