Author Topic: Harddrives - nice pictures  (Read 7135 times)
Online NoopyTopic starter
    • Richis-Lab
« on: May 14, 2019, 09:10:16 pm »
Hi all,
I did some high resolution pictures of two old WD Caviar harddrives (22100 and 22500).
Of course with some die Pictures too.  8)
If you are interested go to:
http://www.richis-lab.de/HDD_WD_Caviar_22100.htm
http://www.richis-lab.de/HDD_WD_Caviar_22500.htm
Text is german...  :scared: ;D
Have fun! :popcorn:
Greetings,
Richard
The following users thanked this post: PeDre, SeanB, BillyD, legacy, MadTux, dom0, sixtimesseven, RoGeorge, kulky64, capt bullshot
Offline simxdx
  • Country: cn
Re: Harddrives - nice pictures
« Reply #1 on: May 15, 2019, 12:39:50 am »
 :-+,Very clear pictures!
The following users thanked this post: Caliaxy
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #2 on: May 15, 2019, 04:46:44 am »
Nice pictures  :-+
Wonder how much tinier is reading head now in Terabyte sizes and how weak signal it produces compared to back then
    • Richis-Lab
« Reply #3 on: May 15, 2019, 05:08:21 am »
Thanks!  8)
I have some newer models lying around here.
Coming soon...  :-/O
I don´t know if you can compare the signals of an old device to a newer one. The technology changed a lot as far as I´m informed...
Offline pwlps
« Reply #4 on: May 15, 2019, 11:37:43 am »
The signal is not so much smaller, in fact it was rather the progress in the reading head technology (AMR,GMR,TMR...) giving more signal strength that allowed increasing areal density.  For example the development by IBM of new heads based on the GMR effect in the 90's allowed to break the technological limitations of the previous AMR generation  (still used in WD Caviar models, WD acquired the GMR technology from IBM circa 1998).
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #5 on: May 15, 2019, 03:14:28 pm »
I know most of the capacity progress is trough narrower more dense packed tracks as speed and linear density goes up no more than 10 times from that 90s drives but total density skyrocketed and have exponential growth
But still they must now processing signal in GHz ranges from head as they get about 200MB/s data rate
Offline dom0
« Reply #6 on: May 16, 2019, 04:25:51 pm »
Interesting.
This kinda reminded me of Hebrew, though it doesn't seem to correspond directly to the Hebrew alphabet. And IBM did do both semiconductor and disk drive research in Haifa.
If you flip it (attached) it looks very much like a stylized kind of Hebrew.
« Last Edit: May 16, 2019, 05:28:08 pm by dom0 »
    • Richis-Lab
« Reply #7 on: May 16, 2019, 06:32:07 pm »
My first opinion was also hebrew.
Interesting idea to flip the symbols.  :-+
    • Richis-Lab
« Reply #8 on: June 23, 2019, 02:46:17 pm »
Hi all!
I have posted some new pictures. This time a hard disk with a GMR-Head.   \$\Omega\$ :-/O
Whole story here:
http://www.richis-lab.de/HDD_Samsung_SV4003H.htm
Have fun! :popcorn:
...perhaps you are interested in a floppy drive too:
http://www.richis-lab.de/floppy.htm
Eventually very similar just bigger...  ;D
    • Richis-Lab
« Reply #9 on: September 20, 2019, 08:23:55 pm »
News on my homepage: A Western Digital Red 3TB
https://www.richis-lab.de/HDD_WD_RED_3TB.htm
Piezos in the pick up and heaters in the head. What a crazy shit. :wtf:
A interesting thing:
Till now I had two WD Red 3TB with bad SMART values.
The boards in both hard disks seem to have a corrosion problem:
In my opinion they use galvanic silver. Cheap and good with BGA but problematic regarding corrosion.
Very bad when you want ot use spring contacts for very fast signals:
I would have chosen gold!  8)
Have fun!  :popcorn:
« Last Edit: September 21, 2019, 06:21:06 am by Noopy »
The following users thanked this post: Miyuki
    • Richis-Lab
« Reply #10 on: November 03, 2019, 04:22:58 pm »
And again a new HDD!
See the details of a Seagate ST-177I:
https://www.richis-lab.de/HDD_Seagate_ST-177I.htm
Everything a little bit bigger:
Of course with die Pictures:
 ;D
Have fun!  :popcorn:
The following users thanked this post: BillyD, Miyuki
    • Richis-Lab
« Reply #11 on: January 04, 2020, 10:46:50 pm »
Do you remember the WD Red silver tarnish thing?
After a lot of time and a query WD gave me the following answer:
"Thank you for waiting for our reply. Our engineers have studied your reports and inform us thus.
We would like to apologize for any trouble this has caused you. After review the surface of the PCB shows silver tarnish which is not a functional or reliability issue. This is expected as the surface finish is silver. ..."
With a little help of Google you find a lot of information regarding the rising resistance of silver tarnish.
I can´t imaging that shouldn´t be an issue.  :o
We will see whether I will get a better answer the next days... ...weeks...
Offline Prehistoricman
« Reply #12 on: January 04, 2020, 11:20:35 pm »
I've seen quite a few HDD PCBs with this look. I think one had issues before I gave the contacts a good scrubbing.
Amazing pics. I love the look of the platter on that old Seagate.
Offline station240
« Reply #13 on: January 04, 2020, 11:29:02 pm »
I have that silver finish on 4 WD green hard drives, after one completely died, I had to clean all the other drives PCBs.
Failure mode is this:
1. Controller gets bad/weak signals from the heads, assumes it's just a bad sector.
2. Controller moves the data to another part of the drive, and marks the original sector as bad.
3. Error rates get worse, controller moves more files, marks more sectors as bad.
4. After days/weeks of this, whenever the computer is on the drive has activity.
5. Actual disk surface has damage from constant moving of files.
6. Drive has more bad sector than it can mark.
7. Attempt to reformat drive as last resort after saving data.
8. Reports over 10,000 unrecoverable bad sectors, marks them as bad then crashes.
9. Reboot shows drive as totally unavailable, to the BIOS!
10. Totally bricked.
    • Richis-Lab
« Reply #14 on: January 04, 2020, 11:43:40 pm »
"Unfortunately" I had to disassemble the HDD before I tried to clean the contacts.  ;D I have four of them left all around five years old. If they ever give bad SMART-values I´ll try some cleaning first.
Thanks! Good feedback is always a reason to do more pictures.  :popcorn:
Sounds absolutely reasonable.
I´m curious wheter I´ll get a better answer from WD than the last one. :palm:
But ok, what should they write? "Hey, we screwed up. Sorry!"  :-//
They design such technical wonderful things and than they mess with the PCB-finish...  |O
Offline TheEPROM9
  • I have a Kali USB and I'm not afraid to use it!
    • EPROM 9 Home
« Reply #15 on: January 05, 2020, 12:36:49 am »
You are giving me ideas for photos withy my macro lens. Like most of you, I have more HDD's than you can shake a stick at.
TheEPROM9 (The Husky Hunter Collectors inc.)
Knowledge should be sheared freely to those who want it.
https://www.flickr.com/photos/146977913@N06/ https://www.youtube.com/channel/UC4vOnjz1G-aM8LddSbrK1Vg https://www.facebook.com/groups/118910608126229/
Offline TheEPROM9
    • EPROM 9 Home
« Reply #16 on: January 05, 2020, 12:38:23 am »
Hi all,
What camera kit did you use & also how did you de pot the chips?
Have fun! :popcorn:
Greetings,
Richard
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #17 on: January 05, 2020, 12:51:16 am »
I have few WD Black 1TB (FAEX) disks that have silver tarnish on PCB pads as well. Used to take controller PCB out, clean pads with erases, put it back together and until next few month it worked fine. After doing this for few times, ditched the drives and bought Toshiba HDDs and Intel SSDs.  :-//
Offline Wimberleytech
« Reply #18 on: January 05, 2020, 03:54:55 am »
Very nice work!!  Have you reversed any old Quantum drives?
What are you using to decap the plastic packages?  HF?
    • Richis-Lab
« Reply #19 on: January 05, 2020, 08:24:58 am »
Thanks!
A quantum drive would be interesting too! Till now I had none but Ebay will help...  :D
The decapping was done with a torch. With a little practise that gives 70-80% good dies depending on the type of chip.
The pics were taken with a "normal" dslr with a reversed 10mm objective and "balgen"-rings.
I have posted the how-to:
https://www.eevblog.com/forum/projects/decapping-and-chip-documentation-howto/msg2666622/
 :popcorn:
Offline magic
« Reply #20 on: January 05, 2020, 08:28:05 am »
Not even sure if HF would work at all, hot nitric or sulfuric is the usual choice.
Even if it works, it would certainly eat the glass passivation layer afterwards and possibly the aluminium underneath(?)
    • Richis-Lab
« Reply #21 on: January 05, 2020, 10:32:10 am »
The magnefication and the quality of the pictures is not as good as possible with a >10k€-Zeiss-Monster but I can easily tilt the objects.
The focus depth is very small but often I can take very nice pictures this way:
https://www.richis-lab.de/IC_02.htm
The following users thanked this post: BillyD, I wanted a rude username
Offline magic
« Reply #22 on: January 05, 2020, 10:54:20 am »
Nice dust spots in the upper left :P
Offline legacy
« Reply #23 on: January 05, 2020, 11:36:14 am »
what do use for taking pics like these?  :o
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #24 on: January 05, 2020, 11:42:21 am »
