Hi tooki,
You are correct, my bad...
Ok, the LTC6268-10 will probably be able to achieve +-1dB with proper construction and trimming.
But again, look at page-16 on "Driving Capacitice Loads".
Keep the load below 5pF, so good pulse response will also require looking very carefully at the PCB design.
Also, this opamp is sensitive to overload at the input, so there really needs to be additional components there to protect the opamp.
The reason you see so few schematics of this type of preamp is that it is quite complex.
With the modern opamps a very large bandwidth is possible, but as soon as you start using something like a Scoop preamp or other device with a large bandwidth, the protections at the input and output play an increasingly important role and requires a lot of knowledge of the whole.
But I don't want to stop anyone's development of a scope preamp, it's a very good way to gain insight of e.g. paracitic properties in electronic circuits.
Kind regards,
Bram
