Nice, I hadn't seen that earlier thread. A lot of good info!
Also the wish list is very helpful. Do you all think BNC ports or SMA ports would be preferable? I was envisioning having board edge mounted, surface mount, SMA ports. But I can't figure out how they would go through the case without having to be soldered in after the PCB was mounted. Maybe I'll do vertically mounted SMA ports that pass through holes in the top of the enclosure?
I would really like to get the enclosure design right, normally that is just an afterthought for me I have to just hack it together at the end
Also LaserSteve, that limiter, what power level would you want it to limit to for your SA (spectrum analyzer?).
-Hunter
