I don't mind if something is out of stock, however, it seems more that these guys are not in control of their stock inventory if over 40% of items are quoted with wrong stock availability.
Totally incorrect stock numbers, or a broken stock backend code, seems to be a Farnell-specific issue (in addition to the manufacturing crisis, of course, which is a separate thing). After over a decade of being a Farnell customer, I almost completely stopped using them about a year ago for this specific reason. Not surprised to hear it's still going on.
Specifically, about 20-30% of the products that were available in quantities for the whole design cycle time (months), and then available just minutes before you order (while adding them to cart), magically disappear after your order is in, and are in backorder.
I have had such horrible service from Farnell that I wouldn't be too surprised to find out they do this on purpose. It would be kinda fraudulent (called bait-and-switch), but would make sense a lot: it's a compelling factor that they seem to have better stock than their competitors, and once you have ordered, you are already "locked in" and are very unlikely to cancel your order - or even cancel the backordered items!
Still, it's most likely their information technology is just broken. Another reason for ditching them was that I don't have hours of cumulated time available for a simple 100-line order just to wait for the website to respond after blocking for minutes, then try again after it crashes, try to sidestep the non-working BOM/CSV import by iteratively halving the list until it passes without crashing the whole website, and so on...
Since I prefer fair play, customer service, and responsive, working website, I have gone with Digikey as my preferred distributor, and have not looked back. Mouser seems to work as well without these kind of issues.
