Author Topic: High speed design  (Read 2655 times)
Offline georgegTopic starter
High speed design
« on: June 20, 2012, 04:10:42 pm »
What are high speed back plane and mid plane design? Why are high speed designs more popular nowadays?
Offline T4P
  • Country: sg
    • T4P
Re: High speed design
« Reply #1 on: June 20, 2012, 04:15:07 pm »
Duh. What is the world now without high speed? USB? SATA3?
Offline Time
« Reply #2 on: June 20, 2012, 05:39:43 pm »
because faster is better.
-Time
Offline typeglob
« Reply #3 on: June 20, 2012, 08:38:21 pm »
... and faster is often cheaper than more at a lower speed. They'll run links in parallel again once they've saturated the bandwidth.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: June 21, 2012, 06:25:13 am »
there will be always room for improvement... USB10, 1THz 1TBps speed 8bit bus... USB20 1PHz 1PBps, 32bit bus. :P
« Last Edit: June 21, 2012, 06:26:49 am by Mechatrommer »
Offline amspire
« Reply #5 on: June 21, 2012, 06:57:29 am »
They will not go back to parallel when they cannot get any more serial speed. They may run multiple serial links - each independent.
Offline ejeffrey
« Reply #6 on: June 21, 2012, 07:34:51 am »
In fact they already do.  PCI express x1 is a single (bidirectional) serial link.  x4 and x16 are multi-lane serial links, but it isn't correct to say that it is a 4- or 16- bit parallel link.  The channels are largely independent at the electrical level (each channel generates its own recovered clock) and the controller stripes data byte-by-byte (not bit-by-bit) over the active channels.
Parallel buses are still the king for extremely high bandwidth, low latency, close range connections like on-chip data bus, a memory bus, or a ADC connection, but as soon as you want to transmit more than a few cm, it is time to serialize (if you want high speed).
