Author Topic: TLC2272 opamp stability at unity gain  (Read 532 times)
Offline AussieBruceTopic starter
« on: May 02, 2022, 04:43:37 am »
Hi, I'd like to use TLC2272s at unity gain (out direct to in-), but the datasheet doesn't specifically state stable at unity gain. It does have specs for phase margin (50 deg), and gain margin (10dB), which from my recollection of my decades ago control unit suggests that it may be OK. Am I likely to be on 'solid ground'?
