So thats the circuit now. I wanna use 2 5532 for lower distortion and Power handling. For the realay, the 072 should Work, since its coil draws only 11mA, for a few seconds.
47uF should be enough i guess, its about 13Hz with a 250ohm load, so way below any kind of frequencies in music.
For the PSU im not quite Sure. I have to Test it Out if 9V is enough, however i tested it with 15v, using a step up converter, thats nice for a stable supply Voltage, but the tiny step up i got from eBay, is noisy as hell. When i Connect the circuit to it, without Sound, its like FM when u have no Connection. Strangely, that completely is gone when music is playing (maybe bc of the load)
