Author Topic: Heating Pad/Mat  (Read 1472 times)
Offline AMK5405Topic starter
Heating Pad/Mat
« on: March 10, 2019, 04:02:14 pm »
I am trying to create a heating mat or pad. My requirements are 110V/220V, 140/150 degrees F, and the largest would be about 36"x40" and the smallest about 24" x 24". Can be rectangular if needed, cut to a specific shape is nice. I have been looking at things like under floor heating, and carbon fiber. The problem is with carbon fiber is the resistance isn't less than 15/20 AMPs. Carbon fiber cord works but winding a cord up and down and providing consistent heat is next to impossible. Any ideas? TIA!
Offline Sceadwian
  • Beware those that tell you the way the world is.
Re: Heating Pad/Mat
« Reply #1 on: March 10, 2019, 04:09:07 pm »
Use the bed heaters from 3D printer, you'd have to use more than one to get that area but the same sites that sell the 3D printer bed heaters will possibly have one's of the size you're looking for. A little bit of Googling based on what you find from 3D printer bed heater sellers should get you almost exactly what you want.
-Because I be, what I be. I would tell you what you want to know if I could, mum, but I be a cat. And no cat anywhere, ever gave anyone a straight answer.-
Offline Cnoob
« Last Edit: March 10, 2019, 06:53:19 pm by Cnoob »
The following users thanked this post: Heartbreaker
Offline Sceadwian
Re: Heating Pad/Mat
« Reply #4 on: March 10, 2019, 06:17:07 pm »
Infrared heaters (several) aimed at what you want to heat might work better. Glass is opaque to IR so you should get even heating.
Offline coppercone2
Re: Heating Pad/Mat
« Reply #5 on: March 11, 2019, 04:11:47 pm »
I think a sick solution would be to put heating strips on copper plate thats soldered to copper mesh and coated with thermally conductive flexible polymer.
With a insulator on top
Pu foam cut into strips like plate mail armor
Mc master sells heating strips that are adhesive backed. They are thick nichrome foil like a maze embedded in rubber. Would be a heavy skirt and press into stuff good
« Last Edit: March 11, 2019, 04:14:47 pm by coppercone2 »
Offline soldar
Re: Heating Pad/Mat
« Reply #6 on: March 11, 2019, 11:32:16 pm »
You cannot set the temperature except by providing more than enough power and a thermostat.
I have built countless bed electric blankets / pads. All you need is nichrome wire and a sewing machine and you can make the size and shape you choose.  I did not provide any thermostat and I made them powerful so I could get into a toasty bed. Spread out they worked fine but one day it was crumpled in a corner under the blankets and it started a fire.
I do not understand what this means. Why don't you use nichrome wire which is the standard for these things?
Offline daniel444
Re: Heating Pad/Mat
« Reply #7 on: March 12, 2019, 06:33:37 am »
can you use a hot air gun???
Offline martin1454
Re: Heating Pad/Mat
« Reply #8 on: March 12, 2019, 06:53:19 am »
Look up Keenovo heaters, they have both stores on Ebay and Aliexpress, and sells tons of different size heaters.
Re: Heating Pad/Mat
« Reply #9 on: March 12, 2019, 07:39:19 am »
Go down the path of Drum heaters. Most of the big guys in Element or Temperature control will be able to make you a custom one. In particular the silicone drum heaters would suit your glass application due to the flex.
Omega not for any reason other than their content is accurate https://omega.com/subsection/drum-heaters-tank-heaters.html
« Last Edit: March 12, 2019, 07:44:23 am by beanflying »
