Author Topic: Heavy Duty Connector Power + Signal  (Read 2559 times)
Offline luky315Topic starter
  • Country: at
« on: January 07, 2014, 04:01:59 pm »
Does anyone know a connector system for automotive use / light trucks ("12V") with at least IP68 and vibration resistant interlock? I need power (5-10A) and a differential CAN signal (100/120Ohm). Is there a system which combines power and signals or is it bether to use separate conectors and cables for signal and power?
Offline Frost
Re: Heavy Duty Connector Power + Signal
« Reply #1 on: January 07, 2014, 04:43:24 pm »
Maybe the Superseal Series from AMP, the Standard-Buccaneer Series from Bulgin
or very rugged the M Series from Lemo?
With two seperate connectors you can combine the Buccaneer 400 with their Mini Series.
Lurch
  • Guest
« Reply #2 on: January 07, 2014, 05:39:15 pm »
https://b2b.harting.com/ebusiness/app/displayApp/%28xcm=ebusiness_espel32&layout=7.0-12_131_125_139_129&uiarea=1&carea=0000100450&cpgnum=1%29/.do
I use loads of Harting industrial connectors. Just making some looms and connectors up currently to replace some that have been in a very heavy industrial application since the 70's and are only being replaced as part of scheduled maintenance.
Offline ConKbot
« Reply #3 on: January 07, 2014, 06:35:54 pm »
The J1939 connector comes to mind.  Already carries a few amps of power and CAN bus signalling for the J1939 bus.  Its kind of big, but should be available.
  • Country: at
« Reply #4 on: January 08, 2014, 01:19:55 pm »
Thanks. J1939 semms nice. A bit bulky and hard to obtain, but robust.
The Buccaneer-Series is also worth a try because there are PCB and panel mounting connectors available.
Thanks again!
