If the usual suspects (noise, ESD), a series resistor, filter cap, clamp diodes, and another series resistor is a good idea.
BAV99 is a good enough diode for clamping. You probably don't want to use schottky (BAT54S being the other common choice) for analog signals due to leakage current.
