Hi
I made a simple electronic project using an ESP32 and some relays (rated for 30A) that switches 13A/230V. This is enclosed on a "project box" that's about 1 liter in volume.
When the switch is on, I noticed the box get pretty hot (the temperature increases about +20°C/+70°F).
The box is not completely closed since there's a non-sealed hole on the top for the wires to come in/off.
Some quick calculation (first time I'm doing it though) shows that 0.2Wh is enough to heat 1L of air to +20°C, so perhaps this is normal heat from resistance of the wires/components.
Does that sound reasonable? One thing that makes me not worry much is that the temperature increases quickly at first, but stabilizes (see graph below, ignore the values in the bottom, they're noise).
Thanks
