Hello:
I would like use plastic to direct the light from a LED on a pcb to a panel 1-2cm in front of it.
I see this done in many products, but was hoping there may be a readily available molded insert that might fit into a hole in the panel and then be trimmed to length to just touch the LED.
No sure if I am explaining this correctly?
Was thinking of just some acrylic rod that could be inserted into a hole drilled in the panel, but thought it would look better to have a dome appearance on the front panel.
Not sure if this could be 3d printed?
Thanks
Tom
