The transformer is rated at 33V - its actually 66V with a center tap (I will measure it just to be sure), the caps in there are 50V, I'm planning on replacing them with 63V caps.
BTW, the stock volume pot is 150K. I was planning on replacing it with an ALPS RK27 but could not find it in 150K, just 100K. Will it do or should I look for a 150K from a different company?
The stock pot also has a fourth leg going to the loudness control, I'm not familiar with this, do modern volume pots have this as well?
BTW, I went through the Mouser catalog last night (I have a printed version at home so it easier than online), but could not find any switch or pot of the type I need. I would highly appreciate it if someone could help me find replacement items for these.
