I don't have a schematic, but it's a wiring mess on the inside. It isn't a problem when the rails are clean of ripples, as there is no noise to couple and jump then..
So I've got 3 options, redo the entire amp myself with proper wiring, ditch the nice metal box,
or
a) find LT1083/4/5-12 somewhere, use 2 of those - I'm not ecstatic about their price and availability... also seems that their ripple rejection seems to be bit low from the charts, even as low as 20db or lower? nope
b) do the capacitance multiplier circuit from the 1st post in the PSU itself - should work, have only one question about it:
Am I correct in thinking that it's only important that TIP35 and TIP36 transistors handle up to 25 amps, and BD139/140 are merely driving them so they don't have to handle the load currents?
