Author Topic: Help ID 2 chips and find datasheets: CS4968AM and ALi M5819P  (Read 157 times)
Offline NexxenTopic starter
« on: March 12, 2024, 02:07:55 pm »
Hello!!
While I was repairing a motherboard I came to the conclusion that probably one of these two is responsible for the no POST.
They  CS4968AM and ALi M5819P. Itried looking for datasheets but I couldn't locate any.
CS4968 should be some clock generator, ALi is a RTC, I'm not sure how to proceed without a pinout.
See pics attached.
The issues I have are stuck Reset and no CLK to cpu (it should read 66MHz but is 0).
Thanks for any help!!
« Last Edit: March 12, 2024, 02:14:18 pm by Nexxen »
Online coromonadalix
Re: Help ID 2 chips and find datasheets: CS4968AM and ALi M5819P
« Reply #1 on: March 12, 2024, 02:14:42 pm »
the CS4968AM    seems  to be the clock generator for the motherboard, this one normally generate many signals
and i see you posted elsewhere too  loll  you give more details there than   here   .....
« Reply #2 on: March 12, 2024, 02:54:09 pm »
Yes, here I just look for another thing.
I use Duckduckgo, but with google I found way more. Not the first time.
I probably have to switch to G...
Posting in multiple places is normal to allow more visibility.
http://biossrc.chat.ru/files/5819pb01.PDF
