Author Topic: help identifing this connector  (Read 1135 times)
Offline BoschiTopic starter
  • just a arduino-guy
« on: April 13, 2019, 03:22:42 pm »
so, i bought a used car and i want to change the stock radio, i open up everything and its not the standard iso connector  |O
if anyone is able to found the pinout even better, but as now im mainly intrested in buying another connector in order to create an adapter to an iso connector (which is the standard/most common one).
it has 15 pin and the whole thing is 42mm wide. the pitch is 2.54mm.
cheers
Offline 6PTsocket
Re: help identifing this connector
« Reply #1 on: April 13, 2019, 05:06:09 pm »
Contact Crutchfield. They specialize in after market radios and the hardware, bezels and adapter cables. It it exists they will have it Phone: 1 844 221 6900.They have an extensive stock of adapter wiring
Sent from my SM-G900V using Tapatalk
Offline DaJMasta
    • medpants.com
« Reply #2 on: April 13, 2019, 06:00:08 pm »
If the pitch is 2.54mm, making an unkeyed replacement for your own adapter should be simple, that's a standard header pitch.  If you really want it keyed or to fit properly widthwise, it's more complicated, but if you want a good electrical connection that you can just heatshrink over or something and not expect it to need to come off any time soon.... it's an easy one to make.
Offline coromonadalix
« Reply #3 on: April 13, 2019, 07:28:22 pm »
seems to be a peugot connector ??
you could take 16 pins dupont connectors,  snip 1 pin,  and do your own connector ??  or any 2.54mm   headers with solderable pins ??
you have some kits with males and female pins  for very cheap prices on Ebay,  search dupont connectors kits, i dont see kits with 16 pins single row ?
https://www.ebay.com/itm/620PCS-Dupont-Wire-Jumper-Pin-Header-Connector-Housing-Assortment-Kit-Crimp-Pin/122676021413?
Or maybe go at a scrap yard trying to find your car and snip the connector,  done that many times.
On the first photo,  it seem   maybe, i say maybe  with a very fine needle  you could  unsnap the black connector from the green housing,  try to see in the slot  if you have a retaining clip / pin ??
I could do it on my suzuki connectors,  remade an iso to suzuki connector,  in case i put my gps 2 din radio in another car.
« Last Edit: April 13, 2019, 07:35:40 pm by coromonadalix »
Offline Bratster
« Reply #4 on: April 13, 2019, 07:31:57 pm »
Have you already done a search for radio adapter and your make model year of car?
That'd be what I would start, unless you have some crazy car that hasn't sold very many somebody will have an adapter already.
Sent from my Pixel 2 XL using Tapatalk
Offline tsman
« Reply #5 on: April 13, 2019, 07:36:32 pm »
What model stereo is that? What car is it in?
